跳转到主内容
加入维修社区 - 创建账户
2014 年 2 月发布的 10.1 英寸平板电脑,运行三星定制版 Android 4.4 KitKat,型号为:SM-T520NZKAXAR
My screen won't come back on when I press the power button
My Samsung tab pro screen does not turn on when I press the power button to get it out of its sleep mode...I see the lights flash on the menu and back key. But the screen stays black. Before I would js hold the power button n the tablet would power off then on. And the screen would come on...but now even if I hold the power button down for a long time the screen stays black. Please help! How can I fix this...or where can I take this to get it fixed?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 9
1条评论
I have the same problem. Did you find a solution?
完成的
添加一条评论
4个答案
最有帮助的答案
Hi Tammy,
Not sure if you still have the Samsung tablet however I followed this tutorial on YouTube -
https://youtu.be/moaGerOZ8CA
I had to try it a couple of times before it would work and also used a bit of tape to hold the cable in place.
Hope this helps.
Grant
这个答案有帮助吗?
得分 2
2条评论:
What kind of tape did you use? We have the same problem and took it to BB 3 times and the cable keeps coming out. How can we secure it so it WON't come out?
完成的
While you have the back off, remove the small piece of tape over the battery connector and gently pry up under the little wires that hold the white battery connector in place. Leave the battery unconnected for a minute and reconnect it. That fixed my problem when the LCD connector didn't.
完成的
添加一条评论
My screen stays black when I push power and vol. The sound comes on that's it still says black
这个答案有帮助吗?
得分 1
添加一条评论
How can I fix press button on my tablet as it won't press
这个答案有帮助吗?
得分 0
添加一条评论
Please my Samsung Galaxy tab 4 does not come on again after it sleeps, no more light anywhere on the device but it will still ring out when calls come in and continue playing the music is on but never come up on screen, even when I press the power button, it will not show on screen unless I press it for long, it will just restart. What can I do this please?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tammy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 26
总计 9,567
