跳转到主内容
The Nerf Maverick is one of the most popular guns in the company's lineup and is beloved for its simplicity and ease of use.
9 个问题 查看全部
Why is my gun's chamber stuck?
The chamber of my Maverick is jammed and I cannot get it to pop out so I can reload it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
If the chamber is stuck its likely one of the following problems.
Friction Between Chamber & Frame
Using WD40 to lubricate the axle which the cylinder is resting on. Sometimes the cylinder will rub up against other parts of the gun if it isn't aligned properly, and spraying WD40 in these areas can make the gun work more smoothly and minimize any damage caused by friction.
Cylinder Not Rotating Correctly
Making sure that the cylinder doesn't have dirt, or anything that doesn't belong on the gun can be a quick fix. It's easy to get a small rock or dirt stuck in many different places of the gun. If a bullet doesn't leave the gun, but you hear it shoot the bullet, the bullet may be wedged somewhere in the gun causing an obstruction.
If neither of the above suggestions work, check out the [Nerf N-Strike Maverick Chamber Replacement|]
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Michael Walker 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 858
