跳转到主内容
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
114 个问题 查看全部
Screen fades or goes black. Pressing left of trackpad brings it back?
Hi!
I have an iBook G3 that works great except for one problem. Every now and again the screen seems to fade or dim, sometimes it fades right to black, sometimes it stays bright.
When I put pressure on the left side of the track pad it stays bright and doesn't fade. What are the possible causes of this and how can I fix it?
Thanks in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Thanks...looks like a big job for a noobie, but I think I will give it a try....maybe even change out that cable while i'm in there!
完成的
添加一条评论
2个答案
最有帮助的答案
Sounds like you may be putting pressure on the display data cable. I would use this guide: iBook G3 12" Display Replacement
and take a look at step 41. I would re-seat the data cable and examine it for problems.
这个答案有帮助吗?
得分 1
添加一条评论
Kathyryn
It probably is your video chip. What happens is the solder lifts and causes what you are experiencing. You have to reseat the soldier around this chip or put pressure on the chip. Google it for answers. There is a french site that gives a solution
Update
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kathryn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,328
