跳转到主内容
数百个光盘驱动器的维修指南。
30 个问题 查看全部
Image DVD (ISO) isn't recognised
Hi,
for Bootcamp I did burn the ISO on a DVD (Using Nero). In the past the iMac (27" EMC 2390) didn't had a problem to recognize it (although it did cost sometimes several attempts before it actually did start to run). Now I get the pop-up the DVD is empty. A movie DVD works perfect as well as a CD. Did burn the ISO again with the same result... Could this be caused by a dirty laser?
I would like to thank you for your advice.
Kind regards,
Frank
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Help us help you.
The more complete the description of your problem is (though it 's clear to you - you've omitted much crucial information such as what OS you're using, there's a lot of those, was the ISO verified as correct after burning? ) the more assistance we can provide, and, the sooner we can provide it.
Have you tried different media or using a slower burn speed -often useful in solving Optical Disk Burn/read problems.
If this answer is acceptable please remember to return and mark it accepted.
这个答案有帮助吗?
得分 2
添加一条评论
How old is your DVD writer because after certain time or use laser lens becomes weak and it read only CD not DVD. Even it can't write DVD. So its possible that your written DVD was corrupted.
You can try to clean your lens with the help of lens cleaner which is available in the market.
Although if it is not working means need to change DVD writer.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nelissen F 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 602
