跳转到主内容
Repair and disassembly guides for garage door openers.
16 个问题 查看全部
Can't adjust travel limits on 2004 Craftsman Garage Door Opener?
I have a 2004 Craftsman half hp Garage Door Opener. Door and rails are in good working order. Opener stop clips seem to be broken. Adjusting screws (for force and travel) turn but do not allow for adjustment.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
Bob,
I just had this issue, look on the top of the opener - check the sprocket that pulls the chain, is it bent/cocked? If so, there’s a gear assembly inside that probably isn’t driving the up/down limit sensor…the nice part is that Sears made these VERY repairable, and you can order a new gear/sprocket part for about $14 - and it will be whisper quiet.
Here’s a link to an Amazon part that fixed my 2000 door opener, check your manual for the specific part.
https://www.amazon.com/dp/B097YPWC6J?psc...
Reach out to me if you have specific questions.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Bob 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 22
总计 1,670
