跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
New screen replacement top left corner doesnt completely flush
I am currently having a hard time fixing an iPhone 5s usually i dont have a problem doing these screens. I have everything set but the top left has the light coming through a little bit and it will not flush like the other parts of the new screen. Help please this is for a customer and i tryed his old screen and it fits perfectly. is it the plastic hinges on top idk please help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
There are a few things that could be causing this, the most common being frame damage. Is the frame bent at all, any scuff marks near the area not sitting flush? The old screen could have similar damage allowing it to sit flush whereas a new screen would not have this damage, possibly causing it to not seat properly.
Another issue could be the quality of the replacement part. I've had parts where the frame would be lifting slightly, almost invisible to the naked eye and only noticeable after seating the screen. The side of the display frame can flex and catch on the side of the phone's metal frame. Another possibility is that the flex assembly for the front camera and proximity is loose and catching on something as well.
Last possibility I can think of without having it in front of me would be a part that was possibly manufactured outside of the proper specs. It happens a lot on copy grade parts, where the glass isn't cut exactly right or something similar.
So, in closing, check everything to make sure all components are on tight, nothing is falling apart during closing the screen, and lastly try another display assembly.
Good luck!
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Richie 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 2,484
