iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2993 个问题 查看全部
Please help ASAP by myself phone screen black,blue line in middle
Hi , I dropped my phone , it's still working as can hear phone ring but screen is black with blue lines
,white line at across top ,faded pink line across at bottom, have done re boot , but not sure next step as been reading it could be contnectos or screen ?? Thank u so much in advance x
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
1个答案
已选择的解决方案
The LCD is faulty and needs to be replaced. There's nothing you can do to revive it as the actual screen is damaged, so there's not an option to just have the glass replaced (which isn't done these days anyway)
Not to worry, this is easily repaired by any authorized outlet or phone repair shop. Or, you can try this yourself and grab a 3rd party high quality LCD replacement for £15 off eBay. But if you have no experience in this field I would recommend taking it to a phone repair specialist in your area.
Don't worry about everything else, the phone should be fine it's just the screen that's causing the visibility issues.
Hope this helps.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Clarke 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 4
过去的30天: 15
总计 1,066
