跳转到主内容
修复你的物品
维修的权力
配件 & 工具
问题已关闭
PowerBook 12inch will not boot up at all
Hi, i have recently acquired a PowerBook 12 inch 1.5 GHZ Aluminum PowerBook.
however when you press the power button, you get a clicking sound from the optical drive but then nothing else, the battery is charging fine from the machine when the powerlead is plugged in, but the machine just refuses to start up, any ideas?
thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Any other ideas?
完成的
添加一条评论
Manta 螺丝刀工具包
日常维修的112个替换头
Upgrade Your Toolbox
Manta 螺丝刀工具包
2个回答
First try re-seting the PMU:
http://support.apple.com/kb/ht1431
这个答案有帮助吗?
得分 0
评论:
hi just tried that made no difference at all
完成的
添加一条评论
I suspect the HDD is faulty and the machine cannot find a valid operating system folder.
Firstly, check there is no disc in the DVD drive by attempting to start up while holding down the trackpad (mouse) button, this should eject any disc in the drive. Assuming no disc emerges, try booting from a 10.4 Tiger OS system disc, insert the OS disc and try to boot(start) while holding down the 'c' key, this asks the machine to boot from the DVD drive.
If you are in luck it will start up.
If not, take it to a competent repairer for an estimate...it probably needs a new HDD.
这个答案有帮助吗?
得分 0
评论:
Normally, with just a dead HDD the computer would still boot, but display a "volume not found" question mark icon.
完成的
Did you read the start of the post? the machine does not power up so all the advise you have given ie checking to rom drive and trying to boot using the C key is irrelevant, read the start of the post...
完成的
To my mind the, your evidence that the CD drive is clicking suggests it MAY be searching for a boot volume in the CD drive as it cannot find one on the HDD.
I can understand your frustration with a broken machine, but your rudeness to someone who is trying to help you does you no credit.
完成的
As stated before all that happens is the drive clicks briefly and thats it, there is no bootup chime ..nothing. My post was not meant to be taken as rude, but is is frustrating when people clearly don't read the whole thread, I have had posts before where you end up going round in circles.
完成的
添加一条评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 4,277
