跳转到主内容
修复你的物品
维修的权力
商店
The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
269 个问题 查看全部
Why won't my controllers connect?
I have an Xbox 360 S, and the controllers will not sync with it. I've tried everything I could find online, and even replaced the rf modulator. I tried plugging them in with a wireless controller with a charging usb cord, and that didn't work either. Any help would be greatly appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
打开所有标签
Mac的RAM升级套装
购买套装
所有选项卡都有足够的 RAM
购买套装
1个回答
Do you have any wireless routers, microwaves or metallic objects positioned anywhere near your console? These can disrupt the signal or wireless controllers. As far as plugging it in to play that only works if you use the play and charge kit. Which asks you to connect the battery pack to the USB cable and that to the console. If after all of this still nothing is working your USB ports may be damaged, or the console itself may be damaged. If you can also try using friends controllers to test whether or not it is the controller that is malfunctioning.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Pat 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 1
过去的30天: 15
总计 1,153
