跳转到主内容
Cen-Tech Seven Function Digital Multimeter . Model number 90899.
8 个问题 查看全部
Why won't the screen show any readout?
I want to use my multimeter to test a battery. The banana plugs are attached and cords are attached to the device, but the screen is not reading anything. My device is turned on and seems to be functioning otherwise.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
The reading screen is either broken or malfunctioning. You may need to replace the screen. See screen replacement guide here. If this does not seem to fix the problem, you may have an issue with the motherboard. Click here to see how to replace the motherboard.
Cen-Tech Seven Function Digital Multimeter Mainboard图片
指南
Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement
难度:
简单
5 - 15 minutes
Cen-Tech Seven Function Digital Multimeter Screen图片
指南
Cen-Tech Seven Function Digital Multimeter Screen Replacement
难度:
简单
10 - 15 minutes
这个答案有帮助吗?
得分 0
添加一条评论
I'm all for fixing stuff and keeping it working, but Harbor Freight literally gives these meters away. They're not worth fixing. i have a stack of spare ones still in the package waiting to be used.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anna Kihm 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 9
过去 30 天: 10
总计 1,677
