跳转到主内容
2.26 or 2.4 GHz / White plastic unibody enclosure
645 个问题 查看全部
Rescuing files from dead laptop's hard drive
My old MacBook Unibody Model A1342 late 2009 laptop won't start. The cause for this is probably a water damage.
Nothing major, just few drops of water in wrong place and that's that, so I'm sure that the hard drive itself isn't damaged. I'm not going to repair the laptop, but it would be nice to have the files from the hard drive.
What are my chances to rescue the files?
I viewed the guide for replacing a hard drive from this site and I'm capable to remove it, but what I should do next to rescue the files?
For example, am I able to connect the hard drive to PC?
I also have MacBook Air, so is it possible to connect the old internal hard drive as an external to it via usb?
Thanks in advance for any help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
of course tony, just buy a SATA/USB adaptor or case like this:
http://www.ebay.co.uk/itm/Slim-2-5-SATA-...
i brought cheapest usb3 case time ago, when i plug, it make an interference that stop network.
maybe find better one.
good luck!
这个答案有帮助吗?
得分 5
1条评论:
Thank you for your response! I will look for those that you mentioned. Even though I deal a lot with computers, I'm kind of inept with computer hardware, so I didn't knew how this kind of procedures are done.
完成的
添加一条评论
添加你的答案
Tony 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 157
