Why is my screen constantly just flickering
When I switch my psvita on and slide it down on the start screen all it does is flicker it like the home button is being pressed continuously. Every time I hold down the home button it stops flickering if I let to of the home button it carrys on flickering please can some one anwser back and also the power button dosenT work at all
I have thus same issue PLZ HELP ITS ANNOYING
由 MarkLord 完成的
Hi did anyone find a solution to this?
由 Christo 完成的
When you say home button, I'm guessing you mean the ps button? Not the action button?
由 iMedic 完成的
That is correct yes, the screen flickers on HOME SCREEN all the time, as if the ps button is pressed continuously. I did take it apart and can confirm that the ps button is not stuck nor touches the pc board.
由 Christo 完成的
Since you can open it and have had issues in that area. Chances are one of the PCBs in that area is damaged. Take a good long look at the circuits in that area and see if anything is damaged, raised, burnt or disfigured in any way.
由 Andrew Fillhart 完成的
