1.7 GHz dual-core Intel Processor (Turbo Boost up to 2.6 GHz) with 3 MB shared L3 cache
109 个问题 查看全部
2.0 ghz 2012 11" MBA, will a 2012 1.7 ghz board work?
I acquired a 2012 11" macbook air that has a bad logic board. The original board was the upgraded 2.0 ghz version, not the base 1.7. What I want to know is if I can put a 1.7ghz board in the computer and have it function normally.
Both boards are from the same model year (2012), my reason for wanting to use the 1.7 is because I just want to make this computer a cheap runner so that my parents can use it. The 2.0 logic board is far more expensive than the 1.7.
I've looked at high res shots of the 1.7 board and they are nearly identical to my dead 2.0 board under a magnifying glass. All the connectors seem to be identical and in the same places, the thing I am curious about is system compatibly. Anyone Know?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
善于维修,即天赋异禀。
与 #ImAGenius 分享您的维修故事
我们都是天才
1个答案
已选择的解决方案
Yes boards from the same model and year swap. In fact the base board is the slower one each year and in most cases the faster board is just a "custom build" of certain parts (CPU or GPUs).
You can verify this by using the compatibility link top right of the logic board parts page.
If this answer is acceptable please remember to return and mark it accepted.
MacBook Air 11" (Mid 2012) 1.7 GHz Logic Board张图片
产品
$299.99
这个答案有帮助吗?
按维修分数 1
评论:
Thanks, accepted answer!
添加一条评论
添加你的答案
Steve 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 69
