跳转到主内容
Released Pre-Fall 1997, identified by model number RM318PA
Why are the projected numbers blurry?
At night when the projection clock projects the time on the ceiling, the numbers seem to be blurry.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
When the numbers appear blurry, the fault may be the lens. The Oregon Scientific RM318PA Projection Clock is not constructed like a tradition projector where light is reflected and then projected onto another surface; rather, the beam serves as a direct light source. If the beam is functioning, try turning the focus wheel which will shift the lens and adjust the sharpness of the numbers. If this does not work, you can try cleaning the lens or replacing it if damaged.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kathy Rowley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 390
