跳转到主内容
The BlackBerry Z10 is a touchscreen-based smartphone developed by BlackBerry, previously known as RIM.
76 个问题 查看全部
Can not be heard through phone
I can dial and answer the phone however I can not be heard as if the phone is stuck on mute
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
DISCOVERY: It is actually a defective headphone jack and not the microphone. I got the idea from another post. After a couple of tests to confirm behavior, I cut the end off an old cable and plugged only the dead/dummy end into the phone. The phone now works like normal for both regular and speakerphone calls. I can only guess that the phone's input jack has somehow become damaged. Unfortunate that for now I have to have this tip/end/blank plugged into the phone but it works
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Teresea 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 116
