跳转到主内容
Fix Your Stuff
Right to Repair
Parts & Tools
Kwickset door handle set with in-knob keyhole.
2 个问题 查看全部
What happens if you pull the key out too soon?
I was rekeying my kwikset door lock and I accidentally pulled the key out too soon, and now neither the old or new key work. I really need some help here, thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
Hopefully, the problem is just that you haven't put the pins back in the correct order. Keep trying with the key in the cylinder until they are flush with the top.
The other potential problem is that you let the top pins fall out. To fix this, you need to pull off the metal spring clip over the pins and, with the cylinder containing the proper pins in place, replace the top pins and springs. Put the clip back on, and you should have a working lock. You may need to purchase new pins or talk to someone with a ready supply.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Virginia 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 10
总计 887
