iPhone 5 stuck on Boot Loop, any ideas to help?
Hello i have bought a water-damaged iphone 5. I soaked it in isopropyl alcohol and removed all corrosion. I had then re-assembled it and replaced the battery. The phone turned on and went onto lockscreen fine. About 10 mins later it turned off while i was charging it (charging port did work) and then contionusly kept going onto apple logo, then turning off again and then back to apple logo. It never passed the apple log. No i am stuck on this and do not know what to do.
P.s the phone oly sometimes turns on by power button and not on charge, usually has to be on charge to have boot loop/ turn on. hope u understnad
I hope someone can help.Mnay thanks in advance.
Look forward to hearing from somone.
UPDATE: Removed battery for 24hrs and now plugged in and it turned on and then shut down again, however the charging port is tempermental i beilve.
由 Lewis Watson 完成的
