跳转到主内容
Released February 2013, identified by model number S6812i. Features a 3.5 inch HVGA LCD touchscreen, front and back camera, and dual-microSIM capabilities.
4 个问题 查看全部
Why won't my phone turn on?
My phone battery was empty so the phone turned off. After being plugged into the charger all day, it still won't turn on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
First at all, try to plug your phone into the charger. If it doesn’t turn on and begin to charge within a couple of minutes, the battery may be dead. If the battery is dead, it will need to be replaced with a new battery.
Second, if the problem persist, it is possible that the phone is turned on, but the display isn’t functioning properly. The backlight or the LCD will need to be replaced.
If the phone still not on, the problem is probably that the logic board is bad and needs to be replaced.
这个答案有帮助吗?
得分 1
添加一条评论
I have a samsung fame lite. It fell but now it can boot up. ALL it does is just the logo samsung blue circle turning but does not boot up
这个答案有帮助吗?
得分 1
1条评论:
Even so it will not turn off
完成的
添加一条评论
why phone dont open n restrating everytime solution samsung galaxy fame
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Sarah Brueck 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 726
