跳转到主内容
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577 个问题 查看全部
S5 stuck on charging battery icon
I did a Galaxy S5 glass/lcd repair and now the device won't turn on. When the S5 is plugged into a charger the charging battery icon appears and fills up with the green stuff, but the phone will not turn on. I tried to get to the boot menu by holding down the power button and down volume button, but I still get nothing. I also tried to get to the custom download page by holding down the volume button and home button then plugging into a usb laptop outlet and I still get nothing. I have lots of experience fixing phones and this is not my first S5 repair. I have done plenty and have never run into this problem. Nothing looks damaged. Has any other techs out there run into this problem and know a fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
Happened to me the same problem replacing the lcd. Any comments could help to resolve the problem.
这个答案有帮助吗?
得分 0
1条评论:
same thing happened to me
完成的
添加一条评论
Try switching the power button connector. It is located under the long piece on the back of the S5 in the upper left corner.
这个答案有帮助吗?
得分 0
1条评论:
press the board into the frame around the power button. The contacts are loose.
完成的
添加一条评论
添加你的答案
DK123 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 14
总计 2,532
