跳转到主内容
不间断电源,UPS或备用电池/飞轮,是当输入电源(通常是主电源)发生故障时向负载提供应急电源的设备。
42 个问题 查看全部
APC Back-UPS CS 500 does not power up?
Hi All,
The above device wasn't holding a charge, so I swapped out the battery, and it appeared to be fine for about a week.
Next thing I know, the "power" and "battery" lights were both on, but VERY dim indeed.
The device has now totally gone off and is unresponsive. I verified that the replacement battery isn't faulty as well.
Can anyone offer any assistance with this please? Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
push the circuit breaker, check the power switch and on board fuses. if all else remain ok then power mosfet maybe busted!
完成的
添加一条评论
1个答案
try to push the circuit breaker, verify the condition of the power switch, check the fuses on-board
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ajoy Chundee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,071
