跳转到主内容
The Samsung Galaxy Note II is a smartphone noted for its combination of a large display and software optimized for an integral self-storing stylus.
USB port had burning smell, won't charge fast, computer not see phone?
  • First symtom was burning smell at USB port.
  • USB charge cable had burn marks on micro end pins.
  • Stopped using that charger.
  • Phone still works.
  • When charging it keeps phone going but battery level doesn't change or takes too long to increase.
  • Burning smell gone.
  • When phone is on it gets warmer than normal about 1/4 the way down from top.
  • Phone is not seen by Computer when connected by USB. Debug enabled.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
my infinix hotnote was connected to my pc via usb cord, all of a sudden the cord stiff there and when i removed i, it emits a burnt aroma and then refuses to charge. please what do you think is the cause or probably what has happen to the phone
完成的
添加一条评论
2个答案
最有帮助的答案
Hi, the Galaxy Note 2 charge port is fairly simple to replace, being a simple flex cable, and will probably solve the issues that you're having. A port can charge, or charge slow, or even appear to charge, and then not, when you have a damaged charge port, all kinds of bad things can happen. I highly recommend that you stop charging it, and replace that charge port assembly. If that doesn't work, then it is time to look at the power management IC, that's a little more of an in depth repair, but not impossible. Hopefully it's just the charge port!
I hope this helps you out.
这个答案有帮助吗?
得分 2
添加一条评论
Seems like you had a voltage spike or were using an aftermarket cable that caused damage to the charging port on the phone itself or the power management unit on the logic board. This would explain the slow charging, etc.
这个答案有帮助吗?
得分 0
1条评论:
If the USB board was damaged would that cause my PC to not see the phone?
完成的
添加一条评论
添加你的答案
paul poco 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 14,121
