跳转到主内容
A 10.1 inch Samsung tablet computer with a 1.4 GHz processor, 1280x800 pixel LCD, and 149 ppi multi-touch display. The model number of the device is GT-N8013ZW. Released August 2012, repair of this device is straightforward.
127 个问题 查看全部
battery not charging or retainig charge
not charging on severeal hours charger ok lead ok work other devices ? is it the battery or charging port or internal electronics forums donot have answers help
to define cause of problem and resolving it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
More than likely it is the charging cable. I have had two break. I am currently looking for the pinout for the cable so I can repair the second one.
Philip
EDIT: I have fixed mine. Here are some pictures. The first picture shows the connector upside down compared to the other two pictures. Hope this helps.
这个答案有帮助吗?
得分 0
1条评论:
Where did you get you cable from?
完成的
添加一条评论
添加你的答案
alex r 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,159
