跳转到主内容
修复你的物品
维修的权力
配件 & 工具
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
3381 个问题 查看全部
No service after transparent back swap
I just changed out a back housing on a Verizon iPhone 5 with a transparent one. Everything seems to work except the cell signal. Even the wifi works. Now that may be obvious to some people because after all the entire thing is now plastic where as before I'm pretty certain that the housing was part of the antenna. Does anyone know of a solution?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Changing it back fixed it. I never did find a solution to make the clear back work.
完成的
添加一条评论
LCD iPhone 屏幕维修套装
预算选项,涵盖在我们的终身保修中。
购买套装
LCD iPhone 屏幕维修套装
削减维修成本,而不是质量。
购买套装
1个回答
I know the frame helps signal so in theory a plastic one would give nothing
I would put it back in old frame just to see if your signal in that
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bryan 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 81
