跳转到主内容
2.3L 4cyl or 3.0L V6, 6th Generation
427 个问题 查看全部
My 98 Accord won't start?
This car has been giving me problems the last 6 months. I had it put on a computer at a Auto Parts store.Answer- inconclusive.Have replaced the battery,and battery cables. Had a new key made( $50.00)Had starter checked.Plus several people have looked at the car. It will start just fine, then one day just won't start. I forgot to mention everytime we did do something to the car it would start. Also it seemed like if it had at least a half a tank of gas it would be fine for a while.It will not jump either.It has died driving down the road, or drove to work, then come out to go home and it won't start. Please any suggestions would be appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论:
Check all your grounds for corrosion. Please describe everything you have done to the car and what problems it had and were or were not fixed? Also does the motor turn over-try to start but just will not fire up? what does it do when you turn the key? Check all electrical connections at battery, starter, plugs, wires, coils, alternator, and also fuel filter. If all check out good then check fuel pressure when it will not start? Could be a possible bad fuel pump. Let us know what you find.
完成的
添加一条评论
1个答案
There is one item you need to check and that's the ignition modual they suffer from dry joints check out on youtube first how to check it out then either buy a secondhand one or take the cover off and solder the cone tions up your self ,I got a 2000 accord ,I don't know your skill set but always fix everything myself what I don't know I get off YouTube and have a collection of how to,s stored on my computer !
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
katie1238 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,853
