跳转到主内容
HP TouchSmart 300 Desktop PC
17 个问题 查看全部
Display not coming on
My computer shut down due to a power surge. Computer powers on but a blank scree.
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 3
添加一条评论
Macbook 电池维修套装
起价 $69.99
Buy Now
Macbook 电池维修套装
起价 $69.99
Buy Now
2个回答
最有帮助的答案
you need to check your all connections between your computer and cpu. if connection are ok then you need to use an other lcd or monitor to check your display. once you will do that then you need to clean your ram and motherboard.
这个答案有帮助吗?
按维修分数 1
添加一条评论
The system control circuitry that powers up the lcd/led screen and/or the display screen itself may be defective; also the motherboard itself may need to be replaced.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Donna 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 8
总计 1,889
