跳转到主内容
Sony Xperia TL / Model: LT30AT / Dual-core 1.5Ghz Krait / Black, White, Silver
3 个问题 查看全部
The screen is frozen and it won't turn off or on
The screen locked and nothing is functioning. Turning the phone off does not help. The only thing that seems to work is letting the battery drain to force restart the phone. Is there an easier way around this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
最有帮助的答案
Try doing a power cycle. To do this hold the Volume Down button and then the Power key simultaneously for about 15-20 seconds. If this does not work, try holding the Volume Up button instead of the Volume Down button.
Make sure to do this while the phone is not plugged into a power source. It also might take a few tries.
If this continuously fails, the battery should be replaced. There is a guide on this page for that.
这个答案有帮助吗?
得分 16
8条评论:
Excellent advice worked first time. Thank you saved me sending it away.
完成的
Oh I love you
完成的
what causes this to happen?
完成的
ankitis beat me to it...…………………..I love you also :-) Worked first time with the volume up advice x
完成的
Thank you - worked first time for me too :))
完成的
显示更多的3条评论
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
thanks. it worked with mine
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nathan Laneau 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 15,815
