跳转到主内容
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
568 个问题 查看全部
Can I add Flash Storage to the installed base Flash of 256GB?
I'm buying an iMac Intel 27" Retina 5K Display and would like to install aftermarket Flash storage up to 1TB or higher.
1) Is aftermarket Flash storage available which will fit into the iMac?
2) If so, can I install the Flash storage on my IMac Retina without destroying the case or inner workings?
3) If so where can I get this Flash storage and the instructions on how to modify the iMac?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Probably not - you can upgrade the SATA drives (HD and SSD) but not the proprietary blade drive slot... no one at this time has a source.
That could change in the future - it took two years for 3rd party drives to become available for early release Retina machines). Hence, the hedge on a solid answer.
If this answer is acceptable please remember to return and mark it accepted.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kenneth Emmer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 189
