跳转到主内容
加入维修社区 - 创建账户
Released Pre-Fall 1997, identified by model number RM318PA
How do I get the projection clock to keep correct time?
The projection clock does not keep correct time even though it is connected to the Atomic Clock.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
After doing some research, I discovered that the unit needs to be resynchronized with the Atomic Clock.
Resynchronization process:
Please note: keep all components within the same 10 feet radius while resynchronizing.
Remove batteries from main unit and all sensors.
Unplug if on AC power.
Allow a minimum of 10 minutes for any or all capacitors to discharge.
Reinstall batteries into any or all sensors first.
Press a paper clip or pin into reset hole in battery compartment.
Reinstall batteries into main unit.
Press paper clip or pin in reset hole in the battery compartment.
The unit should re-sync immediately, however it may take up to 10 minutes for the unit to completely resyncronize.
Projection Clock RM318PA Troubleshooting.
完成的
添加一条评论
1个答案
Hi! It may be that the clock needs to be reset.
Try the link below if you're having trouble finding the reset!
Oregon Scientific RM318PA Reset
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kathy Rowley 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 35
总计 1,743
