跳转到主内容
Installed new broadcom card... now no bluetooth
So I just installed a new Airport/bluetooth card i(4.0 ie BCM94331PCIEBT4CAX) into my Early 2011 Macbook pro... when I turn my computer on... I was happy to see my Wifi Working but it says no bluetooth hardware detected.
Since there is WIFI doesn't that the card works?
Or is it a defective card?
Could I have not attached something properly?
Or is it a software issue???
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
David, I would dry a PRAM reset before declaring it defective. Sometimes this forces the machine to recognize new hardware. Also, what do you see under System Profiler under bluetooth? Anything there?
这个答案有帮助吗?
得分 3
1条评论:
I'd also reset the SMC.
完成的
添加一条评论
I just tried to no avail
It also shows nothing under system profile
这个答案有帮助吗?
得分 1
1条评论:
double check if the bluethoot connector is well inserted in its socket.
完成的
添加一条评论
添加你的答案
David Burkholder 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 306
