跳转到主内容
Lightweight cordless vacuum sweeper for picking up crumbs and other small waste.
Why won't the SweeperVac turn on?
The Swiffer SweeperVac refuses to turn on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
最有帮助的答案
The most common reason for this happening is a dead battery. The battery must either be charged or replaced.
If it is not the battery, the mechanism for turning on the device might be jammed. This mechanism is in the handle. To check this, try removing the handle entirely and examining the opening at the bottom while pressing the handle button. If it broken, there is little you can do, but is more likely to simply be stuck in which case pressing against the inner mechanism might free it up.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Adeoluwa 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 3,786
