跳转到主内容
The Canon PowerShot SD500 Elph is a 7.1 megapixel camera with a 3x optical zoom. The camera was released February 2005 and is identified by model number PC1114.
Why won't the flash on my Canon PowerShot work?
When I try to take pictures, the flash will not go off when I want it to.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
The flash may be turned off on the camera. Press the circular button surrounding the "FUNC. SET" button to the right turns the flash on and off.
The bulb also may be burned out, causing the flash not to work. The flash bulb may be replaced but if the entire flash assembly has been damaged you will need to replace the entire flash assembly.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Delaney Reardon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 11
总计 1,924
