跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3531 个问题 查看全部
iPhone 5s DIY solar charger recognized but not charging?
I finished building a USB solar charger DIY kit I bought from KipKay earlier today, and my phone kind of bugs out whenever I use it. When it was first completed, it was charging perfectly fine, with no errors whatsoever. After a while, "This device may not be supported" errors started showing up, and my phone started charging backwards. I replaced the cable, and the errors eventually went away. However, my phone is still "charging backwards", and sometimes charging stops during connection.
I've tried cydia tweaks, but all they do is remove the error, and the phone refuses to charge.
It probably has something to do with the charger and not the phone, but is there anything I can do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
Charging backwards thats the first time I've heard that one..
Dont you mean charger doesn't work and the percentage is just dropping normal lol
这个答案有帮助吗?
得分 0
添加一条评论
can you give me the link so i can buy one too?
这个答案有帮助吗?
得分 0
添加一条评论
Hi there,
As I know there is an charging protocol for all iphones, if the charging current goes unstable it will stop charging and displays “The device may not be supported“, so I guess the power of your solar charger must be very small, less than 6 Watt. For charging iphone 5s or any IOS phones, you need a power bigger than 6.5 Watt and comes with USB 5V output, the bigger the better.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Austin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 239
