跳转到主内容
The Nokia Lumia 720 is a Windows Phone 8 device manufactured by Nokia. It was released in April 2013.
24 个问题 查看全部
motherboard not working due to water log in the phone.
nokia lumia 720 motherboard is not working due to water log. what has to be done?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
malavika, what you want to do is to prevent corrosion failure. Stop using, charging or trying to turn your phone on. Remove the battery and totally disassemble your phone, then clean it with +90% isopropyl alcohol. This will displace the water and stop corrosion. It it okay to submerge a board in isopropyl alcohol. Check this guide to show you how to do it. If was written for an iPhone, but all the pertinent steps apply to your phone as well Do not forget to clean the connectors on the board as well as the cables. Check your board for any missing or damaged component. After that, air dry all the components. Then re-assemble with a new battery This is not optional but a must, to avoid failure later on. " Water damage is the toughest to trouble shoot and to repair. Once you have it properly cleaned, replaced the battery and checked all the components, reevaluate for any damage. Hope this helps, good luck.
这个答案有帮助吗?
得分 0
添加一条评论
Some IC revome that y
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
malavika 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 487
