跳转到主内容
Repair guides and troubleshooting for the Acer Aspire 5, a series of laptops on the Windows OS by Acer.
20 个问题 查看全部
It turns on, and that's it :-(
My computer is a Acer Aspire v5, with windows 8. It will only light up a black screen where I can move my mouse across without lags, but this is how far it comes, the Acer logo appeard the first time I turned it on but after I shut it down with the on/off button it just shows me the black screen with the possibility to move the mouse.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
I have spammed the F8 button and alt+ F10 at start up, nothing happend.
完成的
添加一条评论
4个答案
Just wanted to confirm a few things..
Did you do a hard power down by holding the power button down for 5 seconds or by just briefly pressing the power button (which would put the computer to Sleep).
I've found this laptop occasionally does not properly recover from Sleeping under Win8, that's why I ask.
Either way, do a hard power down by holding the power button for 5 seconds.
Unplug the laptop and find the battery disconnect pinhole switch underneath (indicated with a picture of a battery lifted up) and using a paperclip press and hold for 30 seconds.
Try powering on again, do you atleast get the Acer logo appearing when powering on?
Let's start from there..
这个答案有帮助吗?
得分 0
添加一条评论
I am having this same problem. I took off the case and pulled the battery to reset the CMOS. That didn't work. The backlit keyboard comes on but that's all. Black when I try to power on. I pulled out the battery and left it out for 5 minutes. Put it back in and nothing. Changed power supply. Nothing. changed outlets. Nothing.
这个答案有帮助吗?
得分 0
1条评论:
Did you ever get yours to turn on?
完成的
添加一条评论
My laptop just shows "Acer exploring beyond limits" that's it doesn't go further than that
这个答案有帮助吗?
得分 0
1条评论:
@upulasi_st3v3 Try removing the battery disconnecting the power adapter and holding the power button down for 60 seconds then reinstall the battery and plug in the power adapter then boot the computer. Hope this helps
完成的
添加一条评论
@upulasi_st3v3 @dmsosb (and bbspige too, but I can't figure out how to @ him\her): How long have you waited for without it starting up?
Just asking because Aspire V5s, especially older ones, can sometimes take an extremely long time to turn on (my three-year-old V5-122P sometimes takes several minutes to start up), so, if you were waiting only a minute or so and then powered it back down, it's possible (although by no means certain or even probable) that it would have eventually started fully.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
bbspige 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 2,316
