跳转到主内容
Buick Century is the model name used by Buick for a line of upscale performance cars from 1936 to 1942 and 1954 to 1958, and from 1973 to 2005 for a mid-size car.
36 个问题 查看全部
No odometer light, other drl functions ok on 1997-2005 Buick Century?
no odometer illuminate, can't see milage
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 11
7条评论
I had the same problem. Before resorting to taking everything apart, try pressing the trip odometer reset button. I was curious to see if it would work. Apparently, changing the display from ODO to Trip ODO, reset the circuit. My display is working without replacing the resistors or taking my dash apart!
完成的
yeah but more commonly you will need to perform repair
完成的
dude....you're a genius. it worked!!!!
完成的
Worked for me too! Who says there is nothing good on the internet!!!! Thanks Jeremy!!
完成的
Didn't work for me? I have a 2000 Chrysler Town and country changed the cluster board, but still nothing? Help and no gauges?
完成的
显示更多的2条评论
添加一条评论
9个答案
已选择的解决方案
Here is a link to aforum discuion and cure for your problem Good luck Ralph
http://www.realworldautomotive.com/forum...
这个答案有帮助吗?
得分 3
1条评论:
+ good
完成的
添加一条评论
Try pressing the ODO/Trip ODO button first. It resets the circuit. My light came back on as soon as I tried it. It will save you much time and headache!
这个答案有帮助吗?
得分 3
添加一条评论
just a couple of bad resistors, cost me $1 for a pack of 5, and you only have to replace 4 of them. http://www.youtube.com/watch?v=84FAjLxoK... that'll talk you through it
这个答案有帮助吗?
得分 2
3条评论:
+ good answer.
完成的
mine had 3 of 4 and need replacement
完成的
What is the wattage for the 150 ohm resistors to buy?
完成的
添加一条评论
Fixed it last night after watching a youtube video http://youtu.be/ebTS25sNOHQ buying a 5 pk of resisters at Radio Shack and watching a video on how to solder and purchasing a soldering iron and metal to solder. soldering http://youtu.be/I_NU2ruzyc4
这个答案有帮助吗?
得分 0
添加一条评论
This happened in my car, the above links are true. There are some crappy resistors inside of the instrument panel, replace them and you are good to go!
这个答案有帮助吗?
得分 0
1条评论:
Havent tried yet but im going to. Im going to have to take dash apart. Pushing button doent work for me. i dred it.
完成的
添加一条评论
The reset button works but then it cuts back off evertime i start the car back up
这个答案有帮助吗?
得分 0
添加一条评论
Didnit continue to track miles while it was out? I may be buying a Buick that has this issue. The sticker on the window says oil change is due in a couple weeks or 89,000 miles. I’m curious if I fix it, if it will show 127k on the odometer meaning the guy had the sticker made up or if the sticker is legit, it will show the ~89k on the odometer.
Basically, my question is, if it burned out at 100 miles and you drove for 300 miles then fixed it, will it show 100 miles or the correct 400 Miles?
这个答案有帮助吗?
得分 0
1条评论:
I know this comment is from 3 years ago, but it still tracks mile. Even if the display is out.
完成的
添加一条评论
It will show the correct 400 miles. The failure only involves illumination, not function.
这个答案有帮助吗?
得分 0
1条评论:
What are the specifications of that resistors?
完成的
添加一条评论
Worked like a charm! Thanks for the tip! :)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jerryo80911 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 80
总计 50,906
