跳转到主内容
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
533 个问题 查看全部
I can't find the fan.
I will replace the hdd in my emc 2210 with the Seagate hybrid. I want to replace the fan too because the error 4mot/1/40000003 hdd-1327 from the Apple Hardware Test makes it seem prudent to replace both BUT, after hours of searching I can't seem to find the exact hdd fan replacement anywhere. Is it possible that only a substitute for:Delta BFB0612HB APPLE P/N 620-4324 is available and I'm one of the few who doesn't know it? It is possible I'm adhering too closely to the model and p/n here? Can anyone steer toward the item I need? Thanks in advance. Kevin
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个回答
已选择的解决方案
Kevinmoore75, the part number for your hard drive fan is 922-8510 and it is readily available at places like this and many others. hope this helps, good luck.
这个答案有帮助吗?
得分 1
评论:
Greetings and thanks for answering. Am I to understand that I've been searching using the incorrect model number? I copied the model number and P/N from the photo on the ifixit instructions outlining the replacement procedure. While looking through various photos I noticed there are distinct differences in shape and wire/connection length (connectors?) on the various fans in the 2210 (cpu and optical drive fans) http://www.applemacparts.co.uk/store/fan..., I've just searched your suggestion and it appears you are indeed correct and I thank you. Question: what about the 620-4324 number? I'd assumed (perhaps foolishly) this number had to do with the wires or connector. Is that the case? Thanks for your help.
完成的
Not sure where that number came from. I went by the partslist for your computer model and that is where I got mine from. here is the compatibility for that part number:iMac 20" 2.0GHz Core 2 Duo (A1224) - Mid 2007, iMac 20" 2.0GHz Core Duo (A1174) - Early 2006, iMac 20" 2.16GHz Core 2 Duo (A1207) - Mid 2006,iMac 20" 2.33GHz Core 2 Duo (A1207) - Mid 2006,iMac 20" 2.4GHz Core 2 Duo (A1224) - Mid 2007, iMac 20" 2.4GHz Core 2 Duo (A1224) - Mid 2008, iMac 20" 2.66GHz Core 2 Duo (A1224) - Early 2009, iMac 20" 2.66GHz Core 2 Duo (A1224) - Mid 2008, iMac G5 20" 2.1GHz G5 (A1145) - Late 2005
完成的
添加一条评论
添加你的答案
kevinmoore75 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 145
