跳转到主内容
Released July 2012, model number MB886 was the third model in Motorola's Atrix lineup. Here you will find a full tear-down of the Motorola Atrix HD from battery to motherboard.
Why won't my device turn on?
The screen is black and the phone is unresponsive.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
It might be because of drained or bad battery, or your battery might be charging, or it might be because of bad display.
这个答案有帮助吗?
得分 0
添加一条评论
I have the same problem. I replaced the Digitizer and the LCD and the Battery but the phone is unresponsive. The green light comes on when plugged into a charger but the phone will not recognize in a computer and makes no sounds or vibrate when the power button is held down. I have tried a real battery pull and a "simulated" battery pull (holding the power and volume down button).
Any ideas?
这个答案有帮助吗?
得分 0
1条评论:
It sounds like your power button could be damaged, or there is damage to the motherboard of the phone. Was the phone functioning before replacing all of those items?
完成的
添加一条评论
There are a number of reasons that could happen, a good place to start would be to charge the phone for 2-3 hours with a genuine Motorola wall charger. If no green LED light shows up on the display, there could be more significant damage to the phone
这个答案有帮助吗?
得分 0
1条评论:
This seemed to work for me. I wasn't able to get ahold of an official Motorola charger but after a few days of on again off again charging and testing one day it just came back on. I have no idea why.
完成的
添加一条评论
添加你的答案
Max 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 13
总计 545
