跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Won't charge after replacing Screen
I replaced the screen with an iFixit screen and it works great. My only issue is the battery won't charge now. Is there something I may have forgotten to connect when putting it back together?
Kinda lost right now.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
Hello it would be hard to damage this part with only a screen replacement .. But replace the dock connecter and see does that fix it .. If not then you have damaged the motherboard somehow
这个答案有帮助吗?
得分 0
1条评论:
I also did try to replace the battery and failed when taking off the adhesive. I might have done something there? I just gave up and and put it back together. Going to try again to replace the battery and see if that works.
Thanks for the help!
完成的
添加一条评论
This happened to me with a different version of iPhone. Long story short what happened is that I somehow broke off a very tiny jumper right next to where the battery connects to the logic board. If you have a magnifier with light, open the phone and inspect the logic board very carefully for broken/missing jumpers. You won't be able to see anything without the magnifier. If that's the case, you'll need to micro-solder to fix it.
Sorry, this is more likely the problem if a battery change doesn't fix the charging issue. Hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
joshuasneider 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 80
