The HP Photosmart Premium All-in-One printer can be used as a printer, copier, scanner. This printer uses a 5 color print system.
14 Questions View all
Question Closed
HP Photosmart Premium AIO Printer C309g paper jam issues?
I have attempted to take the paper out of the printer but it still will not become unjammed. I do not know what else to do.
Add a comment
1 Answer
Make sure you have inserted the correct size paper (20-24#). Also, make sure the paper is loaded correctly. There should be no more than 25 sheets in the tray and it needs to be aligned correctly. Remove all paper from the paper feeder of the printer and make sure there is nothing obstructing the path.
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 310
