跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Cellular issue - Others cannot hear me and I cannot hear them
I have an iphone 5 that is having issues with I make phone calls. I cannot hear anything when making a call and other cannot hear me. Both the speaker and ear piece are working fine because both functions work when using skype, textfree and textplus to make a phone call. It shows connection to the network like normal but for some reason when placing the call nothing can be heard.
I have tried to restore the iphone multiple times with no luck. It could have been on IOS 8.0.2 but it is currently updated to 8.1 so I am not sure what the issue is. To my knowledge this phone has never been opened or had any repair made to it. Could there be anything inside of the device that got loose or could be replaced to fix this.
Thank you in advance for your reply.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
4个答案
I'm having this exact issue, did you ever find a fix? It's driving me crazy!
这个答案有帮助吗?
得分 0
添加一条评论
I have exactly, but I still could not solve the problem
这个答案有帮助吗?
得分 0
添加一条评论
Please help us iFixit
这个答案有帮助吗?
得分 0
添加一条评论
Probably your Audio Decoder Amplifer aka audo ic what controls your cellular line for mic and speaker is faulty.
This IC does his job only if you are making calls.
So yes, your mic and speaker could work normally at voice recording but when you make a call this conversation is going from the AUDIO IC. Replacing it is not so easy without soldering skills. Search for audio ic iphone 5 and you will see what i mean.
Hope you got your answer and good luck fixing your iphone
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 131
