跳转到主内容
The Flip Ultra HD is a digital video camcorder by Pure Digital/Cisco, discontinued in 2011
16 个问题 查看全部
How can I fix buttons on Flip Ultra without breaking the camcorder?
My flip video ulta 2nd generation camcorder was bumped on its side last week and a few of the buttons stopped working. mainly the up, down, left, and play buttons. I can still record and turn the device on and off. It also still works with my computer.
I attempted to open up my camcorder, thinking I could solve the problem on my own. I've seen the tutorials on how you disassemble a older version of a flip video and though it wouldn't be that different. I ran into some problems after unscrewing the two half's. The top part just won't separate as smoothly as I thought. like it's hooked or glued together on the inside. I stopped in fear of damaging my ultra more. I've looked all around the internet for a better step by step guide on how to repair flip ultra 2nd generation buttons but have found none. I've even tried going through the customer service like first but to no avail.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
That's good news. I would write your comment under an answer an accept your own answer. This way the question gets archived and might help the next person with ur CAM and issue.
完成的
添加一条评论
4个答案
已选择的解决方案
I FIXED IT!
I went drove around to some local repair stored to see what they had to say about my flip ultra. They all told me the same deal, how it was more economical to just buy a new one. Figuring that was my only option, I got over my fears of breaking the camcorder and pried it open. I unscrewed it first, of course, then slowly worked it apart. I wasn't able to get it all the way off but I opened it enough to see what was wrong.
That part that connects the two half's was loose and even came off all the way when I pulled it open two wide. it was a simple matter of putting it back in place to fix the buttons. I feel so ecstatic to have fixed something. Not only that, but, I finally have something to contribute to this site! I want to make a more in dept explanation later. for now though, I'd like to enjoy my flip ultra camcorder 2nd generation
这个答案有帮助吗?
得分 3
添加一条评论
The reason you had trouble seperation at top is: There are two screws holding it. They drive from the front of the camera. You must detatch the small plate above the lens. Pry from just above lens. It's mostly glued, but clips on the top. Detaching this plate will reveal the two screws your having trouble with.
这个答案有帮助吗?
得分 1
添加一条评论
I can post this on my blog if you are interested I have several thousand Flip fans visit
http://www.myflip.co.uk
这个答案有帮助吗?
得分 0
1条评论:
That would be wonderful! Yes, I would like that very much.
完成的
添加一条评论
It is not much difficult to fix the ultra flip button. Visit this link https://bestcamerashub.com/ they are really working great. They have detailed articles and reviews on cameras and their accessories.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ashley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 3,777
