跳转到主内容
The Honeywell Cool and Refresh Mini Tower Fan is a two-speed fan paired with a Febreze scent cartridge that cools the air and helps eliminate bad odors.
3 个问题 查看全部
The fan blades won't spin--how to fix?
I can hear the motor whirring inside when I first turn it on but it takes awhile for the fan blades to actually start spinning. How can I fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
The fan blades could be damaged. You can replace the blades, or see if there is anything blocking their movement. There could also be a problem with the motor as a whole. Use this guide to check the fan blades and replace the motor.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Armando Jacob Espinoza 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 45
总计 12,506
