跳转到主内容
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 个问题 查看全部
Trackpad replacement from MB Pro 15'' Unibody Mid 2012
Hi,
Can I use a trackpad from Macbook Pro 15 Unibody Mid 2012 to replace on Macbook Pro 15 Retina Display Mid 2012?
Update
Thanks for answer. However, I was able to check catalog compatibility before I asked the question.
What I'm wondering is that anyone tried to fit that trackpad from unibody Macbook Pro to Retina Macbook Pro?
Question is asked because there is no compatible trackpad in catalog itself, it comes only with top case(retina compatible) and massive price tag.
Since they both look the same (or almost the same), I'm asking if anyone tried and can confirm it works, if that explains better my intentions.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Catalog says NO
You might get faster/more accurate results to contact iFixit customer service directly using the link below.
This is the volunteer DIY help forum. We are not affiliated with iFixit directly in any way.
If this answer is acceptable please remember to return and mark it.
MacBook Pro 15" Unibody (Mid 2009-Mid 2012) Trackpad图片
产品
$59.99
这个答案有帮助吗?
得分 0
1条评论:
Not even remotely close in any way.
完成的
添加一条评论
添加你的答案
Michal 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 222
