跳转到主内容
A tablet released by Toshiba in July 2011, identified by model number AT105-T1032.
11 个问题 查看全部
Why is my Thrive not charging?
I have tried everything from buying a new charger to replacing the battery, but nothing works. What could the problem be?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
I have been having the same issue, though just yesterday I turned on the tablet and it was charged. I have quite a lot of Apps, and I began to wonder if low disk space could interfere with some software aspect of the charging/battery monitor process.
完成的
添加一条评论
4个答案
最有帮助的答案
It sounds like you have a possible charging port issue. Try replacing your charging port using the charging port replacement guide.
这个答案有帮助吗?
得分 1
添加一条评论
If you can find the stand. you can test to see if it is the charge port. The stand has a power adapter port built in. It has to be the stand with the HDMI port in it. I have found the batteries really need a power save app.
这个答案有帮助吗?
得分 0
添加一条评论
There is a resistor, possibly being used as a fuse, that goes out on most of these units. Replacing the resistor seems to solve the problem. If you can power / charge the tablet from the dock but not from the charge port, it is probably because of this resistor, rather than the charging port itself. I have repaired hundreds of these tablets with this issue. If requested, I will try to post a photo of the resistor in question.
这个答案有帮助吗?
得分 0
3条评论:
Could you post a picture of this resistor and how to fix it? Thanks
完成的
Please post picture of resistor location for charger port for the thrive tablet, thankyou
完成的
Please post pic
完成的
添加一条评论
Please point out resistor that acts as a fuse on power port board, this is for a Toshiba Thrive tablet.
thank you.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kason 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 2,102
