How Do I Fix a Leaking Solenoid?
My Etha is leaking from the solenoid. How do I fix this?
There are two common causes. First, turn the pressure on the regulator down and check for leaks again. If the output pressure of the regulator is too high, the solenoid may not be able to handle the extra pressure. If it still leaks, you will most likely need a replacement solenoid. These can be ordered from Planet Eclipse, or your local field might have one. Once you have a new solenoid, we have a replacement guide for you here.
这个答案有帮助吗?
Hay all I have a vibe marker and the solenoid has exploded is there anywhere I can get another 1 from and I am in Western Australia cheers
Mine don't hav a gauge on it
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 2,689
