跳转到主内容
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
20 个问题 查看全部
What screwdriver should I use?
Hello there, I will be taking apart my 3DS ( Wifi card problems ) and I've been doing some research and it seems that the #00 Screwdriver which people recommend MIGHT strip the screws. Is this true? and if it is true what screwdriver should I use?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
Alex, any screwdriver "MIGHT strip the screws". That is where the importance of good tools comes in. I prefer to use quality tools only, and invested in a set from here. The chances are slim to strip screws with the right set of tools.
这个答案有帮助吗?
得分 2
添加一条评论
I used the smallest phillips screwdriver I had, and it worked fine but you have to press down firmly on them to make sure they grip tight enough without stripping.
这个答案有帮助吗?
得分 2
添加一条评论
if it they arent coming dont force them. Apply a drop and i mean a tiny drop of oil (wd-40, pb blaster, trumpet oil, car oil, whatever). you need to let the drop of oil work in there for 20 seconds or so and try again. it is best to work the screw in and out meaning tighten and loosen it to get it free and even after its free you might have to tighten and loosen to work that oil in there. It will come out like this with patience
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Alex 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 580
