跳转到主内容
初代iPhone(又称iPhone 2G)。型号为 A1203,存储容量有4GB、8GB、16GB可选,机身颜色仅有黑色搭配金属铝。维修初代iPhone是容易的,需要耐心,一些工具和焊接技术。
224 个问题 查看全部
Why does my Iphone think it has an accessory?
Two weeks ago, I was in Mexico, and had my iPhone in an iSymphony charger/speaker combination. Since, It thinks it is still attached to an accessory, asking me the question "do you want to turn on Airplane mode?. it tends to drain the battery, and I cannot shut it off!
I have reset, and restored the device both as an old an new iPhone, it still won't go away.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
6个答案
已选择的解决方案
I once had a customer who had the same issue, was in an isymphony setup. It caused a high energy draw into the dock connector and shorted the 28th pin. You need to replace your dock connector on your phone. Ifixit should have the parts...
这个答案有帮助吗?
得分 1
2条评论:
Erm, no they don't
完成的
They don't have it. Can you tell me what pin the 28th is, maybe with some magnification and a dental pick, I can clear the short?
完成的
添加一条评论
最有帮助的答案
carefully clean the dock connector of your iPhone with a dry SOFT toothbrush and a little compressed air. You may have some debris shorting out some of the pins.
If this doesn't help, its possible the device you connected it to has caused internal damage (some devices "Made for iPod" are not "Made for iPhone" and can damage newer devices).
这个答案有帮助吗?
得分 2
添加一条评论
This reply may be redundant, but yes everyone is right on the money with water damage and dock connector issues causing this problem. Definitely check your dock connector for pocket lint compacted down in it. I have seen iPhones with so much fuzz jammed into the dock port that the power charger won't even lock into place properly! If you get a little moisture on this "lint jam" it can short your connector.
Unfortunately, it is nearly impossible to replace a dock connector on a 2G because it is so intertwined with the midframe and also requires removal of top glass and LCD because the flex assembly is also part of the home button. (Man I'm glad Apple changed this design with the 3G!) You'll likely damage more stuff trying to replace a dock connector on a 2G than it's worth.
I suggest buying the entire 2G top glass/midframe assembly (provided of course you don't have water damage evident on the logic board) I've used this unit from Hong Kong for $98.00US (free shipping) a few times(Cosmax I believe is the company name and expect 14 days for delivery). It makes easy work of just about any 2G repair since all you're going to use from the broken phone is the logic board, camera, aluminum back housing with head phone/button flex assembly and the black plastic outer antenna cover.
这个答案有帮助吗?
得分 1
添加一条评论
Sometimes these symptoms can occur from water damage to the dock connector area and/or corrosion in and around the dock connector from humidity/moisture. You can try to clean the dock connector with some alcohol on a cotton tip but this does not always work, your best option would be to examine the extent of internal corrosion and replace your dock connector.
这个答案有帮助吗?
得分 0
2条评论:
Thanks, OPK. I fixit does not have the docking connector, any idea where I can get it? I don't believe Apple sells those kind of parts!
完成的
the dock connector assembly is readily available for around the US$30.00. This is one place u can get some parts (I assume it is a 3g you are talking about but they have parts for all models) http://is.gd/4XEOn Good Luck :)
完成的
添加一条评论
OPK, You ROCK! Haven't fixed the dock connector yet, but my new symptom is the camera view on the screen is in vibrant reds, with a little blue in the black areas. Does this suggest the corrosion is progressing?
这个答案有帮助吗?
得分 0
添加一条评论
rhutchis I suggest you crack it open and take a look, the corrosion should be relatively obvious. I am not 100% on your camera issue, it could be related but I am not sure.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
HUTCH000 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 8,837
