跳转到主内容
第二代HTC One被称为HTC One(M8),它具有双闪存和新的Sense 6 UI,并于2014年3月25日发布。
201 个问题 查看全部
Sound receiver replacement. Other people cannot hear me.
Hello
I recently drop my phone into the water. Everything work beside the sound reciever, now I can't call other people because they can't hear me. Where can I find the part? Where will replace this part for me?
Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
Other people can't hear you proves that your MIC is broken. The microphone of M8 is on the USB board, so you may need to try to replace M8 USb board at first.
That's the repair guide https://www.youtube.com/watch?v=QQjJkkok...
And that's the original replacement http://www.witrigs.com/oem-charging-port...
But if it still fail, you maybe need to check the motherboard connector. So hope the USB board replacement works.
这个答案有帮助吗?
得分 0
添加一条评论
My Htc e8 mic only works on speaker: other people can not hear me unless I turn on the speaker phone. What's the problem?
这个答案有帮助吗?
得分 0
1条评论:
I chatted with HTC guys and they claim custom ROM installed is the problem.
Any idea
完成的
添加一条评论
If you dropped it into the water and dont open it up and clean all the parts with alcohol and an ultrasonic cleaner it will probably show more issues later on when corrosion sets in.
这个答案有帮助吗?
得分 0
添加一条评论
change the mouth piece
Update (10/15/2015)
change your phone's mouth piece
Update (10/15/2015)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jimmy wong 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 3,387
