跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3531 个问题 查看全部
问题已关闭
Home button click function not working when pressed
Hi all,
Had a water damaged 5S which I ended up taking apart and replacing the screen on.
All back together and (mostly!) working - ironically the touch ID works OK but the home button normal pressing function doesn't.
I've looked at the cable and was very careful with this all through - what have I missed ?
Dock connector won't currently charge or connect either but that was working when I tested the assembly prior to the screen being replaced.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Well you may have a case of thermal phimosis. It's simple dude :p
The ribbon has been partly shorted out due to the water damage.
With the charging port I would go for the same concept. Remember that water doesn't necceserily damage until it reaches certain temperature due to its composite density.
When you charged it the first time it was enough to ruin the rest of it.
这个答案有帮助吗?
得分 0
1条评论:
Disaster averted ...
I realized that, eventually, none of the bottom items worked, IE the headphone socket, the speaker etc.
The bottom loom was damaged partly by the water and partly by the plug parting company. The home button plugs into this loom and had therefore partly stopped working.
I replaced the loom across the bottom, with a new lightning connector and the home button now works perfectly.
Looks like things could have been considerably worse!
Lesson learned ....
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 146
