跳转到主内容
Released July 12, 2002. Identified by model number K45SSWH.
33 个问题 查看全部
Oil or grease leaking into mixing bowl?
My KitchenAid mixer has recently been leaking some type of oil or grease out of beater shaft. It sometimes drips into the mixing bowl! Do I need to replace the grease in my mixer or is it one of the seals? Thank you!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Your mixer should never be leaking grease, so the lubricant for the gears inside your mixer has probably separated. This can happen due to overuse, underuse, or age, so you should clean out and replace the lubricant. A good guide by eReplacementParts for doing that can be found at How to Fix a KitchenAid Stand Mixer That is Leaking Oil.
这个答案有帮助吗?
得分 1
添加一条评论
The KitchenAid website answers this question…. It is COMPLETELY normal, esp if you do not use the mixer often, and it is FOOD GRADE oil so it will not harm you if some gets into whatever you're mixing. DO NOT open it and replace the grease, the grease only needs replacing or topping up if the unit makes a grinding noise so don't tamper with it unless it grinds.
Why people come to these places to ask questions about their hardware instead of emailing the company that made the item is BEYOND me but good luck
这个答案有帮助吗?
得分 1
2条评论:
Trying to get ANY information from Kitchen Aid is hopeless.....Youtube is more helpful.
完成的
Seems like a design flawvto me. If I replace the grease, it won't be long until it leaks again. Ascan engineer who has designed many pieces of sealed equipment, It shouldn't be too hard to seal the grease from leaking. I'll take our machine apart and see if there is any way to retrofit a fix, but from experience, it usually takes adding seal glands and gaskets to the design. I see a lazy company here.
完成的
添加一条评论
添加你的答案
Chris Gonzales 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 16
过去 30 天: 91
总计 12,361
